Re: M clutch issues...again
Posted by Duner Wi on May 17, 2002 at 19:36:43 from (63.50.8.240):
In Reply to: M clutch issues...again posted by Dave from MN on May 17, 2002 at 08:16:58:
I had a 3 fingered clutch do what you describe once. I had just installed it and it would not release after a few minutes. What happened was one of the three finger pivot point bolts had pulled thru the nut and one side oof the pressure plate would not release. Might be possible the clutch plate is rusted to the flywheel or pressure plate if it has sat for a time after you installed it.
Post A Followup
: Re: Re: M clutch issues...again
