Re: Re: super c firecrater instruction sheet.
Posted by dan on May 18, 2002 at 04:29:25 from (68.83.34.37):
In Reply to: Re: super c firecrater instruction sheet. posted by Dick Davis on May 18, 2002 at 03:18:05:
if you have a way to scan it and send it over the computer that would be ideal. the sheet I realy need though is the one that would tell any other modifications to the engine that need done like timing or valve lash.thanks. I am not sure if an H would be the same as a super c.My rings had a groove on the inside wich I installed up. there was 1 chrome ring I put on top, the Iron ring next and then the oil ring. It runs ok and compression is good. I hope they were right. I might choke a parts man if not. there was no paperwork in my set at all.
Post A Followup
: Re: Re: Re: super c firecrater instruction sheet.
