Re: Re: Wheel bearings/seals: Can anybody help?
Posted by Bruce on May 18, 2002 at 07:15:22 from (216.179.6.210):
In Reply to: Re: Wheel bearings/seals: Can anybody help? posted by Dave_Id on May 18, 2002 at 06:09:09:
Dave: Thanks for your response. The bearings are OK. I cleaned the old grease out of them and repacked. The races are fine too. What's a seal cup? I didn't see anything like that in the assembly. The new seals I got are IH and yes they are expensive. #21.00 each. They are lip seals, and don't look anything like the original. Question: Should the felt washer and seal be installed in the hub first, or should they be put on the axle shaft before you slide the hub on? Thanks.
Post A Followup
: Re: Re: Re: Wheel bearings/seals: Can anybody help?
