Re: Re: J.D.carb on a M
Posted by Pete1468 on May 19, 2002 at 11:58:49 from (205.188.198.167):
In Reply to: Re: J.D.carb on a M posted by randy hall on May 19, 2002 at 10:17:54:
I've run one on my div 4 MTA for over 2 years now. Not every one believes that you can make one work on a M. Have you pulled your M with the natpa before Randy?
Post A Followup
: Re: Re: Re: J.D.carb on a M
