Re: I.H.C 450 clutch slipping
Posted by joe on May 19, 2002 at 18:47:48 from (66.43.207.226):
In Reply to: I.H.C 450 clutch slipping posted by Rick on May 19, 2002 at 17:38:18:
I would reccomend getting an I&T Shop Manual for your tractor. I will describe how to adjust the clutch, but the fact that it just all of a sudden stopped would sort of lead me to believe that you have something more serious wrong and will need to split the tractor. But first, of course, try adjusting it:
-remove the spring between the clutch throwout shaft and t.a. throwout shaft
-there is a small rod that runs between the clutch throwout shaft and the TA throwout shaft (the clutch one is the front shaft). Loosen the lock nut on this, and remove the pin from the back (TA end) of it.
-On the rod that runs from the clutch pedal to the clutch throwout shaft, loosen the lock nut, and take the pin out of it on the pedal end. Turn the clevis to obtain 1.25 inches free travel (measured from the rear frame cover to the clutch pedal). Tighten locknut. If there is a small bolt with setscrew on the bottom of the clutch pedal, adjust this to get 4 inches of full pedal travel. Replace pin in rod.
-Place TA handle in forward (high) position
-On the rod that runs from the TA handle to the TA throwout shaft, loosen the locknut and remove pin from clevis at throwout shaft end of rod.
-push and hold the TA throwout shaft as far counter-clockwise as possible without forcing, and hold there for the next step.
-Adjust the clevis (mentioned two steps ago) to provide 3/16 inch between the inserted pin and the forward end of the elongated hole in the clevis. Tighten locknut for this clevis. Install pin.
-Re-install spring removed in step one
-On the rod that goes between clutch throwout shaft and TA throwout shaft, adjust it so that it is as short as possible without changing the position of throwout shafts when the pin is inserted into the clevis on it. Tighten locknut and insert pin.
Hope this helps, and good luck!
Post A Followup
: Re: Re: I.H.C 450 clutch slipping
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
