Re: FACT OR FICTION??????????????
Posted by Ace Schrunk on May 19, 2002 at 19:38:53 from (67.25.239.190):
In Reply to: FACT OR FICTION?????????????? posted by BIG JOHN on May 19, 2002 at 19:11:06:
I to changed maney 6V to 12 volt, 12 regulator battery gennerator bulbs put resistor on coil or you will burn the points not much difference in starters mostly, on 400 450 with the firecrator pistons, mostly did not help much should have had bigger starter a good gear reduction starter would have been better. 706,806 came with 12 volt - ground gas 1 battery diesel 2 6V battery and a 12 volt gennerator. NAPA had a different starter gear for 656 don't know why but they did and it did not work because cannot change 1 gear without the other, maybe why never had different starter for 400,450.
Post A Followup
: Re: Re: FACT OR FICTION??????????????
