Re: Farmall 460 steering loose
Posted by Ace Schrunk on May 19, 2002 at 19:44:21 from (67.25.239.190):
In Reply to: Farmall 460 steering loose posted by kev@ia on May 19, 2002 at 14:53:33:
you are right all most come off the sleeve in side the housing that the rack is in is an ecentric sleve and you will have to turn it to move the rack closer to the pinion. If it has not been out in a long time will be tight as HH. Better take it out and clean it up and but in new O Rings.
Post A Followup
: Re: Re: Farmall 460 steering loose
