Re: FACT OR FICTION??????????????
Posted by joe on May 19, 2002 at 19:53:58 from (66.43.207.226):
In Reply to: FACT OR FICTION?????????????? posted by BIG JOHN on May 19, 2002 at 19:11:06:
It is FICTION!!!! A 6 volt generator will only pump 6 volts. The regulator, to be correct, should really be called an amperage regulator. You need a new generator, regulator, bulbs, battery, and resistor for the ignition. The reason that 706's, etc, have two 6 volts is that when you hook them in series, you get 12 volts - you string two sets of 3 cells together to get 6 cells- the same number as a 12 volt battery. You definitely need a 12 volt generator for a conversion.
Post A Followup
: Re: Re: FACT OR FICTION??????????????
