Re: Re: Re: First time I put the M to work today.
Posted by Doc on May 19, 2002 at 20:29:38 from (24.118.180.79):
In Reply to: Re: Re: First time I put the M to work today. posted by Ken Christopherson-NOT SURE ABOUT THE ELECTRICAL on May 17, 2002 at 21:30:15:
If the battery is low, 15-20 minuyes of running will not bring it up with a generator. Try a battery charger and get the battery fully charged and then try it. The other thing would be to charge the battery and bring it someplace that has a load tester and check it. Let me know how it goes. Doc
Post A Followup
: Re: Re: Re: Re: First time I put the M to work today.
