Re: still searching for serial #
Posted by K.B. on May 20, 2002 at 11:27:57 from (209.163.14.146):
In Reply to: still searching for serial # posted by jtwaldo on May 20, 2002 at 10:47:27:
I have the parts book for the Farmall 200, 230, 240 and 240 Utility. According to it, the serial number plate on all of these models is located on the right side of the clutch housing. I would have to go look to be sure, but the plate on my 240 is about 2 1/2"x4". That 7 screw, 5 screw, A is a casting code. It means that the piece it is on was cast on July 5, 1955. A=1955.
Post A Followup
: Re: Re: still searching for serial #
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
