Re: Do I *NEED* a generator for my H?
Posted by The Dukester on May 20, 2002 at 17:13:15 from (65.89.18.166):
In Reply to: Do I *NEED* a generator for my H? posted by Pete in PA on May 20, 2002 at 10:32:35:
I have 3 tractors that use generators. In 6 years two of the generators "failed" and I had to have them repaired, but it was no problem, there is a decent auto/electric specialist in our area and he fixes generators up for all us antique tractor people--and he is reasonable too. While it's true generators don't charge as good as alternators, a generator and regulator in good shape will keep your battery charged up up quite well if you don't run your tractor at low rpm too much. Most real restorers keep the generator on their tractors as alternators are the first thing critics look for on restored tractors. There's usually a good auto/electric shop in most areas(not in cities sometimes--tough) that will fix generators and be reasonable about it.
Post A Followup
: Re: Re: Do I *NEED* a generator for my H?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
