Re: engine swap for farmal l 100
Posted by Hugh MacKay on May 20, 2002 at 17:17:22 from (209.226.106.54):
In Reply to: engine swap for farmal l 100 posted by ray adams on May 20, 2002 at 16:42:22:
All C123 engines will fit your Farmall 100. That will include 100, 130, 140, SuperC, 200, 230 and 240. The engine was used in many other applications. The C113 engine used in A, B, C and Super A will bolt up but will have a bit less hp. There was some discussion last week on this page about C135, reaction was mixed as to whether it would bolt up, If C135 will fit it will increase hp .
Post A Followup
: Re: Re: engine swap for farmal l 100
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
