Re: Points ignition
Posted by TomH on May 20, 2002 at 17:34:33 from (205.140.32.215):
In Reply to: Points ignition posted by Jim Woodson on May 20, 2002 at 17:09:42:
Should be the same gap as with 6V. Original coil with ballast resistor should have roughly the same high voltage output on 12V as without resistor and 6V.
Post A Followup
: Re: Re: Points ignition
