Re: Points ignition
Posted by Merlin on May 21, 2002 at 02:06:27 from (209.205.160.62):
In Reply to: Points ignition posted by Jim Woodson on May 20, 2002 at 17:09:42:
Jim, like Tom said, don't forget the ballast resistor in the wire before it gets to the 6 volt coil. The points won't change, and they should be set at .020. The ground will now be neg. too instead of pos.
Post A Followup
: Re: Re: Points ignition
