Re: Re: HELP!!!
Posted by jal-SD on May 21, 2002 at 06:29:09 from (64.68.166.199):
In Reply to: Re: HELP!!! posted by sHan on May 21, 2002 at 06:19:30:
Did you get the governor linkage in the little slot on the carb right when you put it together? If its not in the slot, it will run, but not run right. (Don't even ask how I know this.) (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: HELP!!!
