Re: fire to points but otherwise still stuck on 44 H electronics
Posted by Bob M on May 21, 2002 at 19:59:12 from (24.169.120.138):
In Reply to: fire to points but otherwise still stuck on 44 H electronics posted by Morgan Hudgins on May 21, 2002 at 19:39:09:
Morgan - Do you have fire coming out of the coil? Pull the center wire out of the distributor and stick a good spark plug on the end. Lay the plug on some metal, crank the motor and see if there is spark.
If you have spark out of the coil, the distributor is out of time or the plug wires are hooked up wrong. If you DON'T have spark, suspect either a bad coil or a faulty condenser.
Good luck - I've been there a few times myself...
Post A Followup
: Re: Re: fire to points but otherwise still stuck on 44 H electronics
