Re: Re: Re: is there any way to tell if the TA is bad on a dead tractor?
Posted by Hugh MacKay on May 22, 2002 at 01:33:42 from (216.208.58.127):
In Reply to: Re: Re: is there any way to tell if the TA is bad on a dead tractor? posted by Jonathan on May 21, 2002 at 20:05:37:
All is not lost on towing tractor backward idea. Pull thr tractor to a grade where it would normally roll backwards on its own. Just place it in 4 or 5 gear, to see if it will free roll in either hi or low in TA. This may not tell you if it is a perfect TA but should tell if it is shot. If TA is good tractor shouldn't move.
Post A Followup
: Re: Re: Re: Re: is there any way to tell if the TA is bad on a dead tractor?
