Cyl Head torque for early M
Posted by Deere Puller on May 22, 2002 at 04:35:34 from (156.77.100.117):
I am ready to re-install the head on my tractor and the torque specs in the I&T manual are 110 ft. lbs. on 1/2" studs. This seems like too much and I would like to verify that this is indeed the number to use. By the way, the I&T manual for these tractors leaves quite a bit to be desired.
Post A Followup
: Re: Cyl Head torque for early M
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
