Re: fire to points but otherwise still stuck on 44 H electronics
Posted by Larry W. on May 22, 2002 at 06:24:34 from (216.228.36.87):
In Reply to: fire to points but otherwise still stuck on 44 H electronics posted by Morgan Hudgins on May 21, 2002 at 19:39:09:
If the points are sparking, then you should have spark to the plugs, unless the coil is bad. The secondary windings in the coil could be shorted. try replacing the coil, or test it if you have an ohmmeter.
Post A Followup
: Re: Re: fire to points but otherwise still stuck on 44 H electronics
