Re: Hydrolics Whining?
Posted by Salvage Man on May 23, 2002 at 07:48:47 from (198.247.178.209):
In Reply to: Hydrolics Whining? posted by George Kelley on May 22, 2002 at 20:16:13:
To get to the orifice screen .You will have to pull the cover off of the pressure relief valve. The cover is spring loaded. I use 2-1/2" 5/16 bolts and washers to pull the cover off. The orifice screen takes a flat screw driver topull out. Also while you have the cover off change the o-ring on the valve that isn't spring loaded. You will have to get the o-ring from your dealer as it is a weird size.
Post A Followup
: Re: Re: Hydrolics Whining?
