Re: Wide Front For M
Posted by Farmer Bob on May 23, 2002 at 09:10:33 from (66.152.73.28):
In Reply to: Wide Front For M posted by JFarmer on May 23, 2002 at 07:54:14:
JFarmer, There are two models that will fit your M. The Std model and the other is the Heavy Duty (HD) model. They are almost identical except for the spindle diameter. The Std model has
1-5/8" spindles and the HD has 1-3/4" diameter spindles.
I believe the main difference between the units for the M or 560 is the length of the spindle, The unit for the M has 13-3/8" long spindles measured from bearing seat to top of shaft. The unit for the 560 has 11-3/8" long spindles measured from bearing seat to top of shaft. Hope this helps you get the right one for the M.//FB
Post A Followup
: Re: Re: Wide Front For M
