Re: Re: Re: Re: is there any way to tell if the TA is bad on a dead tractor?
Posted by Jonathan on May 23, 2002 at 12:33:46 from (64.91.162.52):
In Reply to: Re: Re: Re: is there any way to tell if the TA is bad on a dead tractor? posted by howard on May 23, 2002 at 04:48:14:
all 4 tires are shot and in need of replacement. The tractor looks good and had no oil leaks except the seal around the pto is gone so it leaks there, but other than that, it's the cleanest old unrestored tractor I've seen.
Post A Followup
: Re: Re: Re: Re: Re: is there any way to tell if the TA is bad on a dead tractor?
