Re: Re: Re: farmall super c hydraulic system
Posted by Dave_Id on May 23, 2002 at 12:43:04 from (67.250.134.101):
In Reply to: Re: Re: farmall super c hydraulic system posted by clair burns on May 23, 2002 at 12:34:37:
Did you work the touch control levers back and forth a dozen times to work out the air? Then did you leave the levers in forward position, stop tractor and refil "Touch Control Unit"?
Post A Followup
: Re: Re: Re: Re: farmall super c hydraulic system
