Re: farmall 460 Questions
Posted by kev@ia on May 23, 2002 at 19:56:04 from (206.72.15.186):
In Reply to: farmall 460 Questions posted by MTBurns on May 23, 2002 at 18:38:04:
*if a 1958 Farmall 460 came with Tourque-Amplifiers?
Be hard pressed to find one that came without.
*what size tire did the factory 1958 farmall 460 come with and did it have factory options for a larger tire size?
12.4 or 13.6x38 was standard
I think a wider 34 was a option as was a kit to mount large combine tires.
*there are 2 different rear axle sizes for a farmall 460 (or so people tell me) one is larger in diameter than the other and i need to know when was the first year that a 460 came with the larger rear axle?
I could not tell you the year, might have been from the first. The heavy one is M size and the light one is H, in corn country the light one is a rare thing! Mounted cornpickers broke the heavy one often enough. Much of the trany of the 460 came from the 350 hence the light axels.
farmer kev
Post A Followup
: Re: Re: farmall 460 Questions
