Re: Wide Front For M
Posted by RPM on May 24, 2002 at 06:40:08 from (63.110.182.225):
In Reply to: Wide Front For M posted by JFarmer on May 23, 2002 at 07:54:14:
There are some differences in Schwartz-A&I wfa, they made std and later so-called HD, these usually had their own 6 bolt front hubs, spindle height/length (vertical) and shaft diameter, also bearing stub to fit each specific tractor front wheel bearings. If you look close at stub for bearings of wheel hubs, they were very good at stamping a part number so you had a fighting chance of determining what it was for. 3273 was for a F460, std axle, using original wheel hub, 3033 was M/450 using original wheel hubs, and so-on.
Post A Followup
: Re: Re: Wide Front For M
