560 clutch housing
Posted by larry on May 25, 2002 at 04:59:29 from (198.109.215.148):
There is two holes on the bottom of the clutch housing,one has a plug and the other is open and right below and to the side of the hydraulic filter.can someone tell me the purpose of this hole?I looked at another 560 gas and it was the same way after I cleaned all the sludge out of it.when I shut mine down some oil drips out of it,I beleive it is hyd.but my oil pan leaks a little(not sure if it is fixed yet)could there be a vacume that is sucking some oil up in it and releasing it when I shut her down?This happened after I disced about 50 acres.This is a freshly built motor could the mechanic done something wrong? HELP its driving me crazy afraid I am going to have to split myself and make sure it is all well
Post A Followup
: Re: 560 clutch housing
