Re: 806 D runs out of fuel
Posted by Honkey on May 25, 2002 at 10:21:42 from (64.68.163.22):
In Reply to: 806 D runs out of fuel posted by Curt on May 25, 2002 at 06:38:42:
Curt,
Using ether on a warm engine in that quantity is bound to do damage. Ether is for cold starting only.
Bleeding the filters is the proper way. If it doesn't start then, you have to bleed the injector lines.
One thing I like about the 66 and 86 series is that they have a hand primer on them. Not so bad if you run out of fuel on them.
They must be JD guys, they get in a habit of using ether, and before long their using it all the time for everything.
Regards,
Matthew in SD
Post A Followup
: Re: Re: 806 D runs out of fuel
