Re: H starter
Posted by Farmall Ed on May 25, 2002 at 13:41:04 from (209.240.222.132):
In Reply to: H starter posted by Phlogiston on May 25, 2002 at 10:17:57:
Its been about 3 years since I replaced one,but as I recall it was fairly easy.After the starter is off the tractor remove the two long bolts holding the starter together,there may be some screws holding a plate inside you will have to remove.Best I remember mine (the bendix) was fastened with a couple of bolts.BE careful with the brushes on reassembly.Hope this helps,someone in this area more recent could probaly help you more.Ed
Post A Followup
: Re: Re: H starter
