Farmall Tractors Discussion Board
Farmall A Dist
Posted by Rick on August 12, 1999 at 04:38:15 from (208.235.149.68):
Removed dist cap from my 1947 Farmall A. Directly behind the rotor is a small plate held on by two screws, I removed the plate to grease and after installing it back the Tractor will not start. The plate has a gear behind it. It can be installed in different positions, What is the correct way of finding the right position of the gear in the dist.
Post a Followup
: Re: Farmall A Dist
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
