Re: Replacing Ring Gear --- HELP
Posted by PeteinNY on May 25, 2002 at 18:41:46 from (66.24.154.149):
In Reply to: Replacing Ring Gear --- HELP posted by Old Guy on May 25, 2002 at 16:57:03:
Old Guy, They gave ya good advice, I would certainly replace the throw out bearing, clutch disc, and pilot bushing while you're in there, and give the pressure plate a good once over too. If you opt to reuse the existing ring gear, make sure you rotate it only 1/4 turn, not 1/2. The engine always stops in one of two places which are 180 degrees apart, so those two spots always get the wear (unless you have run it alot with a bad starter drive which could mess it up all the way around.) and make sure to intall it with the beveled cut edge out. Pete
Post A Followup
: Re: Re: Replacing Ring Gear --- HELP
