Re: Re: EXHAUST AT EYE LEVEL
Posted by Kevin W on May 27, 2002 at 05:22:17 from (64.33.191.86):
In Reply to: Re: EXHAUST AT EYE LEVEL posted by gene b on May 26, 2002 at 15:24:26:
This is a good idea Gene B, now put the rain cap on the extension. If you leave the tractor outside, the pipe is covered. If you need to take the extension off to get the tractor in a shed, the rain cap is also off but the roof protects the engine.
Post A Followup
: Re: Re: Re: EXHAUST AT EYE LEVEL
