Re: Unloading Valve 560 ?
Posted by Ace Schrunk on May 28, 2002 at 05:01:34 from (65.103.164.207):
In Reply to: Unloading Valve 560 ? posted by George Kelley560 on May 27, 2002 at 18:26:04:
In front of the tin work just in front of the gear shift you will find a block about 2-1/2 x 4 with 4 3/8 hex head cap screws the reliefe valve is behind the same block so you will need to take 2 screws out and replace with 2 longer screws then remove the other 2 because of the spring for the relief valve, but the unload valve is in that block.
Post A Followup
: Re: Re: Unloading Valve 560 ?
