Re: Why is there oil in my distributor ?
Posted by gene b on May 28, 2002 at 06:23:41 from (63.186.36.75):
In Reply to: Why is there oil in my distributor ? posted by Paul Shuler on May 27, 2002 at 21:20:53:
was the journal where the seal goes good or worn a little you might need a speedy sleeve on the shaft so the seal has a good surface or else it wont last keep checking the hy level remember there isnt any pressure on the pump until you use the rockshafts so if its leaking oil without any pressure on the pump your seal isnt doing its job
Post A Followup
: Re: Re: Why is there oil in my distributor ?
