Re: distributer
Posted by jtwaldo on May 28, 2002 at 08:05:50 from (199.79.251.7):
In Reply to: distributer posted by stupid on May 28, 2002 at 07:30:49:
I replaced the points and condensor in the distributor on my 200 and had a similar problem. The shaft turned freely and after I put the points/condensor in, the shaft was hard to turn and made a scraping noise. I found that in my case it was the screw that you use to adjust the points. I had to grind a little off of mine. Reassembled it and shaft turned freely again. Maybe you have a similar problem. I took everything back out and saw that the shaft moved freely then started putting stuff back in one at a time then check to see if the shaft moved.
GOOD LUCK!! hope this helps
Post A Followup
: Re: Re: distributer
