Re: Re: Re: Farmall 230 How Much Tranny Oil Does It Hold?
Posted by drizler on May 29, 2002 at 07:42:00 from (12.23.26.27):
In Reply to: Re: Re: Farmall 230 How Much Tranny Oil Does It Hold? posted by joe on May 28, 2002 at 16:16:17:
Thanx for the info on the quantity. I will dump in the 5 gallons and that will bring it up half way which should be enough. I don't have any plate on the top of mine except the entire 100 lb cover. There is a filler plug to the right of the shifter. I will just have to stick it and mark the rod rather than fool around searching for some overflow which may not exist. The machine is one of the last being a 59.
One last thing is the hydraulic pump fed in any way by the oil in the base? That light oil doesn't seem the best choice for a rear end to me, all my other stuff uses GL5 which is much more the gear oil. Thanxs for the info.
Post A Followup
: Re: Re: Re: Re: Farmall 230 How Much Tranny Oil Does It Hold?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
