Re: 574 BRAKE PROBLEM
Posted by Red Baron on May 29, 2002 at 09:10:14 from (165.139.135.249):
In Reply to: 574 BRAKE PROBLEM posted by MARK on May 28, 2002 at 19:46:26:
The bleeders are on top of the axle housing. They are usually full of dirt. I always remave them and clean the dirt or they may not bleed properly. If your brakes continue to loose pressure than you probally have a leak around the brake piston in the axle housing.The o-rings tend to get brittle and flattened out over the years. The axle housings will need to be removed inorder to replace the o-rings. If you have questions e-mail and I will try to help.
Post A Followup
: Re: Re: 574 BRAKE PROBLEM
