Re: injector pump
Posted by Honkey on May 29, 2002 at 11:11:58 from (64.68.163.17):
In Reply to: injector pump posted by Wade on May 29, 2002 at 07:10:07:
Wade,
An injection pump is a very presicion piece of equipment. When they are dissassembled they need to be calibrated after assembly on a test stand, to ensure proper fuel displacement.
If you had trouble starting it, you will be ahead to get a rebuilt pump on exchange. The head is the most expensive part. However, most places won't warranty a pump unless you exchange your injectors as well. They won't stand behind a pump that seizes due to a bad injector. The choice is yours. If it were me, I would get both, injectors and a pump. It don't take long to get to $1500, at least then you will know what you have.
Matthew in SD
Post A Followup
: Re: Re: injector pump
