Re: Re: Farmall A and Farmall Super A
Posted by Hugh MacKay on May 30, 2002 at 01:14:15 from (216.208.58.99):
In Reply to: Re: Farmall A and Farmall Super A posted by Red Dave on May 29, 2002 at 18:43:57:
One of the problems facing prospective buyers today is 50 years of sometimes not exact rebuilding. I have run across Super As that have had the touch controll removed, motors changed, serial tags removed, etc. I even saw a 140 with A front wheels. One ty-rod was A vintage the other was 140. He claimed tractor was original.
Torque tube on Super A was different from A in that A did not have the flat top for mounting touch controll on. I am not sure on this one but A s I have seen are Mag. ignition and Supers are coil ignition. Is that when change ocured?
Post A Followup
: Re: Re: Re: Farmall A and Farmall Super A
