Re: Can a MD be started on diesel?
Posted by Gene on May 30, 2002 at 12:18:43 from (65.56.63.98):
In Reply to: Can a MD be started on diesel? posted by jmyt_47 on May 30, 2002 at 11:57:48:
jmyt: I've started a SMD from rolling down hill while it was hot (Just killed it near idle) Starting from cold would be hard. The older MD's had low compression around 14 or 14.5 to one and that's barely enough to light off the fuel charge. The SMD's were some better at 16/1 I think. The whole design was not engineered to be direct start. Ring gear would be one iem that was not intended to take that extra load... and the list would continue on from there.. Gene. (Hey..your miss seeing that smoke when switching over..that'be no fun.)
Post A Followup
: Re: Re: Can a MD be started on diesel?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
