Re: Re: 6 to 12 Volt Generator Conversion on Farmall A
Posted by Freddie Boy on May 30, 2002 at 13:10:24 from (24.151.42.83):
In Reply to: Re: 6 to 12 Volt Generator Conversion on Farmall A posted by Merlin on May 29, 2002 at 23:42:22:
The points don't know the difference between 6-12 vlts but the condensor does, need to get rid of the ballast resistor and find a 12 volt condensor(maybe sm block chev or similar)that will fit in dist. then it will work fine.Truly dont know how much voltage that resistor cuts from 12 volts but I will check it tonight and report back. For now-fred
Post A Followup
: Re: Re: Re: 6 to 12 Volt Generator Conversion on Farmall A
