Re: Can a MD be started on diesel?
Posted by Haas on May 30, 2002 at 17:16:52 from (166.72.245.19):
In Reply to: Can a MD be started on diesel? posted by jmyt_47 on May 30, 2002 at 11:57:48:
Yes, but I don't recommend it as a regular thing. All the gas start ignition stuff was gone off my MD when I got it and it was not running but loose. After getting it all cleaned up and ready I could not get it to start on gas (turned out to be because the timing was 180 degrees out). So I decided to give it a shot of ether, since it would crank but somewhat slowly on diesel. Took two shots of ether and it started right up and it was certainly cold, as it had not been run for a few years. I think the folks I got it from had been using it that way since it had no ignition wires.
Post A Followup
: Re: Re: Can a MD be started on diesel?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
