Re: Re: Re: Steering Sector BIG NUT Loose on A
Posted by Step by step long on May 31, 2002 at 05:56:33 from (216.241.143.186):
In Reply to: Re: Re: Steering Sector BIG NUT Loose on A posted by Keith A on May 30, 2002 at 21:13:22:
Well it's quite the job but I will try to give you a step by step. 1. Remove hood, front grill. 2. Drain radiator and remove it from tractor. 3. Jack up tractor and support it so the weight is off the front wheels, I used 4x4 blocks under the clutch housing to support it. 4.Remove the 2 bolts from axle pivot pin, remove pivot pin. Remove front axle and steering linkage from tractor. 5.Remove steering wheel. 6.Remove the big cap on the front of the steering gear box and turn the steering wheel shaft out through the hole and remove it. 7. Remove the 4 bolts holding on the front bolster and remove it from tractor, this baby is heavy use a jack, hoist, or help when you remove it so you don't drop it on your foot. 8. Turn front bolster upside down, remove bolt from steering arm and remove steering arm. If your steering arm has a square hole you have the old style like me. I understand that at sometime this was switched to a round sector shaft with a key. 9. Remove 4 bolts and split the lower and upper housings. 10. At this time if the sector shaft pulls out your e clip is missing, it should be securely held to the top bearing. 11, Remove 3 bolts from bearing retainer and remove sector shaft and bearing. 12. My bearing was stuck in the housing, if you get to this point you will see that it is impossible to get in there with anything to pull it with. I finally cut mine out with a Dremel tool and small cutting wheels. 13. Clean the assembly and all the parts, replace seals and bushings as needed, place bearing retainer over top of sector shaft, install bearing on shaft, then the e clip. Install the shaft and bearing into the upper housing and install the 3 bolts into the bearing retainer. 14. From this point on reassemble using the steps above in reverse order.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
