Re: farmall c hydraulics
Posted by Steve K on May 31, 2002 at 12:29:57 from (204.131.210.1):
In Reply to: farmall c hydraulics posted by rkg on May 31, 2002 at 04:07:01:
Cut into pressure line (Smaller steel tube) route to an open-center spool/control valve for the device you wish to operate, return from this spool/control valve to the touch control side of the tube you cut. This how mine is and it works ok. The block method previously mentioned would look better but it has a restriction that this method does not have.
Post A Followup
: Re: Re: farmall c hydraulics
