Re: M one speed
Posted by Dick Davis on June 01, 2002 at 03:36:43 from (205.188.196.52):
In Reply to: M one speed posted by Dann on May 31, 2002 at 20:50:46:
Check all the throttle/governor/carburator linkages for free movement and proper attachment hardware. Then check the control rod that runs horizontally from the governor to the carburator. This rod is inside a 3/4" metal tube and at the carb end has been known to be re-installed incorrectly by more than one fixer upper. Sorry this isn't more technically correct, maybe someone will explain it better. Good luck and let us know what you find. Dick
Post A Followup
: Re: Re: M one speed
