Re: IH fuel line problem
Posted by BIG JOHN on June 01, 2002 at 14:22:26 from (205.188.198.151):
In Reply to: IH fuel line problem posted by Jackson on June 01, 2002 at 10:01:25:
Fuel should pour out of the tank. Sounds like you have crud in your system that pluged it up when you ran out of gas. Yes you need to have your system vented, usually this is done at the fill cap with two small holes in the cap.
Post A Followup
: Re: Re: IH fuel line problem
