Re: Need some advise on pilot bushing removal
Posted by Bill Hires on June 01, 2002 at 17:06:11 from (128.206.231.162):
In Reply to: Need some advise on pilot bushing removal posted by Paul shuler on June 01, 2002 at 16:36:42:
I have filled the pilot bushing with grease and then used a rod that fits in the bushing, hit the rod with a hammer. If you are lucky it will pop out.
I have used a bolt tap and threaded the pilot bearing, then install a bolt and use a slide hammer, or gear puller to pull it out.
Post A Followup
: Re: Re: Need some advise on pilot bushing removal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
