Farmall Tractors Discussion Board
Re: M 3pt ??? - Help
Posted by john d. on August 12, 1999 at 12:10:24 from (206.141.74.34):
In Reply to: M 3pt ??? - Help posted by Jim Meadows on August 12, 1999 at 07:59:19:
It's not the ideal setup, but I've got a loader and a 3pt on my M, and use them independently of each other with the lift-all (belly pump) system. Live hydraulics would be nice, but not something I've felt a strong urge to invest in at this point. I run the loader off the right port and left front port, and the 3pt off the left rear. I installed a ball shut-off valve in each line, letting me "park" the loader or 3pt in a given position when using the other attachment. If you have single acting cylinders on these units you do NOT have to run any return lines to the reservoir. Oil will return to the reservoir through the single line to the cylinder when pressure is released.
Post a Followup
: Re: Re: M 3pt ??? - Help
