Re: Specs. For Farmall A
Posted by BIG JOHN on June 02, 2002 at 14:31:07 from (152.163.194.192):
In Reply to: Specs. For Farmall A posted by Andrew (OH) on June 02, 2002 at 13:53:37:
Andrew, you might want to allow a little more width as tires mounted in or out and wheel weights could add as much as 20". Gene B.'s measurement is the axel width end to end. If you are asking for hauling reasons I sure would also ad several hundred pounds like Gene says for fluids and weights etc. GOOD LUCK
Post A Followup
: Re: Re: Specs. For Farmall A
