Re: 300 Farmall Clutch adjustment
Posted by Steven@nd on June 02, 2002 at 18:56:11 from (12.23.184.51):
In Reply to: 300 Farmall Clutch adjustment posted by Jim on June 02, 2002 at 16:37:52:
You need to get an owner's manual or the I&T shop manual and get your clutch and TA adjusted properly. When you push the clutch in the TA should release into low range and allow you to shift easily.
Next time you shift, pull the TA lever back and see if it is easier - if so your linkages are out of adjustment.
Steven
Post A Followup
: Re: Re: 300 Farmall Clutch adjustment
