Farmall Tractors Discussion Board
Re: IH 484 Clutch
Posted by RickB. on August 12, 1999 at 15:01:07 from (205.231.28.89):
In Reply to: IH 484 Clutch posted by Gerald on August 11, 1999 at 21:33:35:
Good quality clutch discs & pressure plates are available from OEM & aftermarket sources for this tractor. The next time it is split, be CERTAIN the flywheel step dimension is correct. If the flywheel was cut or turned without turning down the step where the pressure plate mounts, the lockup pressure on the disc will be insufficient to ensure good disc life.
Post a Followup
: Re: Re: IH 484 Clutch
